Command reference
security key-manager external barbican create-config
Create a Barbican KMS configuration
This command creates a Barbican configuration which can be enabled on a Vserver.
-vserver <Vserver Name> - Vserver
The name of the Vserver.
-config-name <text> - Configuration Name
Each configuration must have a configuration name which is unique within a Vserver.
-key-id {scheme:​//(hostname|IPv4 Address|'['IPv6 Address']')…​} - Barbican Key Id
The HTTPS URL of the Barbican secret.
-application-cred-id <text> - Keystone Application Credentials ID
The ID of the Keystone application credentials.
-keystone-url {scheme:​//(hostname|IPv4 Address|'['IPv6 Address']')…​} - Keystone Authorization URL
The HTTPS URL of the Keystone authorization service.
[-verify {true|false}] - Verify the Barbican Host
Use this parameter to verify the authenticity of the the Barbican Host. The verify value can be either true or false.
[-verify-host {true|false}] - Verify the Barbican Host's Hostname
Use this parameter to verify the hostname of the Barbican configuration. The verify-host value can be either true or false.
[-proxy-type {http|https}] - Proxy Type
Use this parameter to specify the proxy type. The proxy-type value must be HTTP or HTTPS.
[-proxy-host <text>] - Proxy Host
Use this parameter to specify the proxy host.
[-proxy-port <integer>] - Proxy Port
Use this parameter to specify the proxy port.
[-proxy-username <text>] - Proxy Username
Use this parameter to specify the proxy username.
[-proxy-password <text>] - Proxy Password
Use this parameter to specify the proxy password.
[-timeout <integer>] - Barbican Connection Timeout in Seconds
Use this parameter to specify the timeout, in seconds, for attempting to connect to the Barbican service.
The example below creates a configuration on a node with the following details: For Vserver vsTest, configuration name: config1, Key ID: https://sample.com:5000/v3, Keystone URL: https://sample.keystone.com:5000/v3, Application Credentials ID: app_cred_id.
cluster-1::> security key-manager external barbican create-config -vserver vsTest -config-name config1 -key-id https://sample.com:5000/v3 -keystone-url https://sample.keystone.com:5000/v3 -application-cred-id app_cred_id
Enter the Barbican Key Management Service application credential secret:
