Command reference
security key-manager keystore upgrade-revert show
Display keystore upgrade/revert status
This command displays current keystore upgrade/revert status.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, then the command displays only the keystore upgrade/revert status of the given Vserver.
[-keystore-type <Key Store Type>] - Keystore Type
If you specify this parameter, then the command displays only the keystore upgrade/revert status with the given keystore type.
[-timestamp <MM/DD/YYYY HH:MM:SS>] - Timestamp of Upgrade/revert
If you specify this parameter, then the command displays only the keystore upgrade/revert status with the given timestamp.
[-status <text>] - Key Store Upgrade/revert Status
If you specify this parameter, then the command displays only the keystore upgrade/revert status with the given status.
The following example displays current keystore upgrade/revert status.
cluster-1::*>security key-manager keystore upgrade-revert show
Vserver                Keystore Type  Timestamp               Status
vs1                    AKV            10/28/2025 15:33:06     Reverting vserver vs1 completed successfully.
