security oidc modify
Modify OIDC Client Configuration
The security oidc modify command modifies an OpenID Connect (OIDC) client configuration. This command can be used to enable or disable the OIDC feature. Enabling or disabling the OIDC feature is a two-step process:
Create an OIDC configuration using the security oidc create command.
Enable or disable the OIDC feature using the
security oidc modifytrue/false`` command.-enabled
Enabling or Disabling the OIDC feature restarts the web server. Any HTTP/S connections that are active will be disrupted. |
[-enabled {true|false}]- OIDC Enabled-
Enables or disables the OIDC feature. If set to
true, the OIDC feature is enabled. If set tofalse, the OIDC feature is disabled.
The following example enables the OIDC feature:
cluster1::> security oidc modify -enabled true
