Command reference
security oidc show
Show OIDC Client Configuration
The security oidc show command displays the OpenID Connect (OIDC) client configuration.
The following example displays the OIDC client configuration:
cluster1::> security oidc show
OIDC Provider: adfs
                              Issuer URI: https://example.com/adfs
                               Client ID: client-id
                      Client Secret Hash: client-secret-hash
                       Provider JWKS URI: https://example.com/adfs/discovery/keys
                       Remote User Claim: unique_name
                  Authorization Endpoint: https://example.com/adfs/oauth2/authorize/
                          Token Endpoint: https://example.com/adfs/oauth2/token/
                OIDC Redirect IP Address: 192.0.2.1
JWKS Refresh Interval in ISO-8601 format: 1h
                          Outgoing Proxy: -
                         End Session URI: https://example.com/adfs/oauth2/logout
                            OIDC Enabled: false
