security saml-sp default-metadata delete
Delete SAML Default Metadata
The security saml-sp default-metadata delete command is used to remove the Security Access Markup Language (SAML) Service Provider (SP) default metadata configuration.
This restarts the web server. Any HTTP/S connections that are active will be disrupted. |
The following example unconfigures SAML SP default metadata:
cluster1::> security saml-sp default-metadata delete
cluster1::>
