security saml-sp default-metadata show
Display SAML Default Metadata configuration
The security saml-sp default-metadata show command displays the Security Assertion Markup Language (SAML) Service Provider (SP) default metadata configuration.
The Service Provider (SP) host indicates the IP address containing SAML SP metadata.
The Certificate Issuing CA indicates the issuing Certificate Authority (CA) of the SAML SP certificate.
The Certificate Common Name indicates the SAML SP certificate's common name.
The Certificate Serial indicates the SAML SP certificate's serial number.
The following example displays the SAML SP default metadata configuration:
cluster1::> security saml-sp default-metadata show
SAML Service Provider Host: 1.1.1.1
Server Certificate Issuing CA: cluster-1
Server Certificate Serial Number: 180D4457AB87E889
Server Certificate Common Name: cluster-1
