security webauthn modify
Modify Webauthn Global Settings
The security webauthn modify command modifies one or more global FIDO2/WebAuthn settings.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver associated with the setting. If this parameter is specified, the setting applies to that Vserver only. If not specified, the cluster Vserver is used.
[-timeout <integer>]- Timeout (ms)-
Modify operation is not supported for this parameter.
[-attestation {none|indirect|direct|enterprise}]- Attestation Conveyance Type-
[-require-rk {true|false}]- Require Resident Key-
[-resident-key {required|preferred|discouraged}]- Resident Key-
[-user-verification {required|preferred|discouraged}]- User Verification-
[-rp-domains <text>,…]- Relying Party Domain List-
Relying party domain list.
The following command modifies the relying party domain list.
cluster1::> security webauthn modify -rp-domains domain.com
cluster1::> security webauthn show
Vserver: cluster1
Timeout (ms): 600000
Attestation Conveyance Type: none
Require Resident Key: false
Resident Key: discouraged
User Verification: discouraged
Relying Party Domain List: domain.com
