snapmirror vserver config show
Display SMas NAS Vserver relationships
The snapmirror vserver config show command displays configuration information for Vservers in SnapMirror Active Sync NAS relationship.
[-fields <fieldname>,…] -
The command output includes the specified field or fields
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-destination-vserver <vserver>]- Destination Vserver-
Name of the Destination Vserver
[-source-vserver <vserver>]- Source Vserver-
Name of the Source Vserver
[-configuration-state {healthy|unhealthy|degraded|pending-setup|syncing|replication-paused|pending-switchback}]- Configuration State-
Configuration replication states include:
healthyindicates that the destination Vserver configuration is in sync with the source Vserver -
unhealthyindicates that the destination Vserver configuration is not in sync with the source Vserver -
degradedindicates that the source Vserver configuration failed to apply on the destination Vserver -
syncingindicates that the destination Vserver configuration is being synchronized with the source Vserver -
replication-pausedindicates that the configuration replication was manually paused -
pending-setupindicates that source Vserver stream creation is pending
[-corrective-action <text>]- Corrective Action-
Corrective action which can be followed to bring the configuration replication state to healthy from degraded or unhealthy
[-creation-time-of-last-applied-change <MM/DD/YYYY HH:MM:SS>]- Creation Time on the Source-
Last configuration modification time on the Vserver
[-out-of-sync <true>]- Is Out of Sync-
Indicates whether the destination Vserver configuration is not in sync with the source Vserver
[-config-resume-time <MM/DD/YYYY HH:MM:SS>]- Configuration Resume Time-
Displays the time configuration replication resumed between the source and destination Vserver
The following example shows the output of the command when SnapMirror Active Sync NAS relationships are created
clusB::> snapmirror vserver config show
Destination Source Configuration
Vserver Vserver State
vs1_dst vs1_src healthy
vs2_dst vs2_src healthy
2 entries were displayed.
