statistics cluster space show
Display a list of cluster space metrics
This command displays space metrics for cluster.
[-fields <fieldname>,…] -
This specifies the fields that need to be displayed.
[-instance ]} -
This specifies the additional cluster metrics details.
[-uuid <UUID>]- Cluster UUID-
Shows information about the specified cluster UUID.
[-name <Cluster name>]- Cluster Name-
Shows information about the specified cluster name.
[-timestamp <MM/DD/YYYY HH:MM:SS>]- Timestamp of Sample-
Shows information about the cluster metrics under the specified timestamp.
[-interval {1h|1d|1w|1m|1y}]- Interval for Collection-
Shows information about the cluster metrics under the specified interval.
[-status {ok|error|partial_no_data|partial_no_response|partial_other_error|negative_delta|not_found|backfilled_data|inconsistent_delta_time|partial_no_uuid|undefined}]- Result Code of Sample-
Shows information about the cluster metrics under the specified status.
[-duration <text>]- Duration for Measuring Sample-
Shows information about the cluster metrics under the specified duration.
[-available-size <integer>]- Available Size in the Cluster-
Shows information about the cluster metrics under the specified size availability.
[-used-size <integer>]- Size Used in the Cluster-
Shows information about the cluster metrics under the specified used size.
[-total-size <integer>]- Total Size of the Cluster-
Shows information about the cluster metrics under the specified size.
The following command lists all the historical metrics for 1 hour interval for cluster
statistics cluster space show -interval -1h
(statistics cluster space show)
Cluster UUID: dcb7040c-adbe-11ef-9e85-005056a7d44b
Cluster Name: sti113-vsim-ucs626q_cluster
Timestamp Status Duration Available Size Used Size Total Size
11/28/2024 19:39:00 ok PT15S 208038580224 32007991296 240046571520
11/28/2024 19:38:45 ok PT15S 208038592512 32007979008 240046571520
11/28/2024 19:38:30 ok PT15S 208038580224 32007991296 240046571520
11/28/2024 19:38:15 ok PT15S 208038842368 32007729152 240046571520
11/28/2024 19:38:00 ok PT15S 208038592512 32007979008 240046571520
11/28/2024 19:37:45 ok PT15S 208038580224 32007991296 240046571520
11/28/2024 19:37:30 ok PT15S 208038588416 32007983104 240046571520
11/28/2024 19:37:15 ok PT15S 208038596608 32007974912 240046571520
11/28/2024 19:37:00 ok PT15S 208038596608 32007974912 240046571520
11/28/2024 19:36:45 ok PT15S 208038596608 32007974912 240046571520
