Command reference
storage iswi initiator create
Create a Software iSCSI initiator
The ` storage iswi initiator create ` creates a software iSCSI initiator. You need to specific the LIF to associate the initiator with.
-node <nodename> - Node (privilege: advanced)
This parameter used to specify the node in the cluster where iSCSI initiator should be created
-initiator-name <text> - Initiator Name (privilege: advanced)
The user defined identifier to uniquely identify the initiator. The name can be alpha-numeric. (8 characters max)
-lif <text> - Logical Interface Name (privilege: advanced)
The iscsi_initiator LIF to be associated with the initiator.
arunhcluster-2::> storage iswi initiator  create -initiator-name iswi1 -lif iscsi_lif
