storage iswi initiator session create
Create an iSCSI session and discover LUNs
This command create an iSCSI session between the initiator and target array.
-node <nodename>- Node (privilege: advanced)-
This parameter used to specify the node in the cluster where session should be created.
-initiator-name <text>- Initiator Name (privilege: advanced)-
Specifies the user-defined initiator name to be used for connection.
-target-name <text>- Target Name (privilege: advanced)-
Specifies the iSCSI target name of an array. This name is unique and is not case sensitive. The target name must conform to this format iqn.1995-08.com.example:string and the following rules:
Contains up to 128 bytes.
Contains alphanumeric characters. The period ".", hyphen "-", and colon ":" are acceptable.
Does not contain the underscore character "_".
-target-ip <IP Address>- Target IP (privilege: advanced)-
Specifies the target's IP address to connect to.
arunhcluster-2::> storage iswi initiator session create -initiator-name iswi1 -target-name iqn.1992-08.com.netapp:sn.3a1c4c068cc:vs.3 -target-ip 10.238.22.136 -target-port 3260
This command creates a session between initiator iswi1 and target array (iqn.1992-08.com.netapp:sn.3a1c4c068cc:vs.3-10.238.22.136)
