Command reference
storage iswi initiator session delete
Terminate the iSCSI session
This command deletes an iSCSI session.
-node <nodename> - Node (privilege: advanced)
This parameter used to specify the node in the cluster where session should be deleted.
-initiator-name <text> - Initiator Name (privilege: advanced)
The iSCSI initiator used to create the session.
-target-name <text> - Target Name (privilege: advanced)
The target to which this session is connected.
-target-ip <IP Address> - Target IP (privilege: advanced)
The specific target IP to which this session is connected.
arunhcluster-2::> storage iswi initiator session delete -initiator-name iswi3 -target-name iqn.1992-08.com.netapp:sn.3a1c4c067dd111e6  -target-ip 10.238.22.136 -targetport 3260
This command deletes the session between initiator 'iswi3' and target array.
