storage iswi initiator session show
Display the iSCSI sessions
This command displays the currently configures iSCSI sessions.
[-fields <fieldname>,…]-
If you specify the -fields fieldname, … parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
[-instance ](privilege: advanced) } -
[-node <nodename>]- Node (privilege: advanced)-
Displays the node information
[-initiator-name <text>]- Initiator Name (privilege: advanced)-
Selects the iSCSI sessions with a initiator name that matches the parameter value.
[-target-name <text>]- Target Name (privilege: advanced)-
Selects the iSCSI sessions with a target name that matches the parameter value.
[-target-ip <IP Address>]- Target IP (privilege: advanced)-
Selects the iSCSI sessions with a target-ip that matches the parameter value.
[-tpgroup-tag <integer>]- Target Portal Group Tag (privilege: advanced)-
Selects the iSCSI sessions with tpgroup tag that matches the parameter value.
[-tsih <integer>]- Target Session ID (privilege: advanced)-
Selects the iSCSI sessions with tsih that matches the parameter value.
[-admin-state {online|offline}]- Administrative State (privilege: advanced)-
Selects the iSCSI sessions with admin state that matches the parameter value.
[-oper-state {created|online|offline|initializing|failed}]- Operational state (privilege: advanced)-
Selects the iSCSI sessions with operational state that matches the parameter value.
[-redirect-ip <text>]- Redirect IP (privilege: advanced)-
Selects the iSCSI sessions with the redirect ip that matches the parameter value.
[-failure-string <text>]- Error string (privilege: advanced)-
Selects the iSCSI sessions with the failure string that matches the parameter value.
arunhcluster-2::> storage iswi initiator session show
Initiator Target Target-ip Target Tpgroup-tag TSIH State
Name Name Port
iswi3 iqn.1992-08.com.netapp:sn.3a1c4c067dd111e6
10.238.22.136 3260 0 1 ONLINE
iswi1 iqn.1992-08.com.netapp:sn.40443506.vs2
10.176.54.219 3260 0 0 OFFLINE
This command displays all the iSCSI sessions.
