system services web file-uploads cleanup-config modify
Update the configuration information for file uploads cleanup task
The system services web file-uploads cleanup-config modify command configures the periodic task to remove incomplete upload files.
[-frequency <integer>]- Cleanup Frequency (in minutes)-
Defines the frequency of the recurring task in minutes. The default is 5 minutes.
[-stale-age <integer>]- Age of stale files to be removed (in minutes)-
Defines the time in minutes after last modified time of a file to be considered stale. The default is 5 minutes.
