system services web file-uploads cleanup-config show
Show the configuration information for file uploads cleanup task
This command shows the configuration parameters of the periodic task to remove incomplete upload files.
The Frequency field indicates the frequency of the periodic task in minutes.
The Stale Age field indicates the time in minutes after the last modified time of a file to be considered stale.
