volume analytics cluster-config show
Display the file system analytics cluster configuration
The volume analytics cluster-config show command displays the cluster level file system analytics configuration. By default, the command displays the following information:
Is Enabled by Default
The following example displays information about the cluster level file system analytics configuration:
cluster::*> volume analytics cluster-config show
Is Enabled by Default: True
