volume quota debug pending-state-change show
Display pending quota state transitions on a SM-as destination
This command displays volumes which have pending quota state change operations for a SnapMirror Active Sync NAS relationship. If no parameters are specified, the command displays the following information for all volumes with pending quota state change operations:
SVM name
Volume name
Pending "quota off" operation
Pending "quota on" operation
Pending "quota resize" operation
[-fields <fieldname>,…]-
Selects the fields to be displayed. Use "`-fields ?` " to display the available fields.
[-instance ](privilege: advanced) } -
If this parameter is specified, the command displays detailed information about all fields.
[-vserver <vserver name>]- Vserver Name (privilege: advanced)-
If this parameter is specified, the command displays information for the specified Storage Virtual Machine (SVM).
[-volume <volume name>]- Volume Name (privilege: advanced)-
If this parameter is specified, the command displays information for the specified volume.
[-pending-off {true|false}]- Pending Quota Off (privilege: advanced)-
If this parameter is specified, the command displays volumes that match the specified pending "quota off" state (true or false).
[-pending-on {true|false}]- Pending Quota On (privilege: advanced)-
If this parameter is specified, the command displays volumes that match the specified pending "quota on" state (true or false).
[-pending-resize {true|false}]- Pending Quota Resize (privilege: advanced)-
If this parameter is specified, the command displays volumes that match the specified pending "quota resize" state (true or false).
The following example displays pending quota state change operations for all volumes.
cluster1::> set -privilege advanced
Warning: These advanced commands are potentially dangerous; use them only
when directed to do so by NetApp personnel.
Do you wish to continue? (y or n): y
cluster1::*> volume quota debug pending-state-change show
Vserver Volume pending-off pending-on pending-resize
vs1 vol1 false true false
vs2 vol2 true false false
2 entries were displayed.
