vserver nvme subsystem host remove-proximal-vserver
Remove a Vserver from the host's proximal list
This command is used to remove the proximal Vserver configuration from subsystem host.
-vserver <Vserver Name>- Vserver Name-
Specifies the name of the Vserver.
-subsystem <text>- Subsystem-
Specifies the NVMe target subsystem.
-host-nqn <text>- Host NQN-
Specifies the NVMe subsystem host NQN.
-proximal-vservers <text>,…- Proximal Vserver Names-
Specifies the name of the Vservers that need to be removed from the proximity to the host.
