ONTAP EMS reference
acp.ioxm events
acp.ioxm EMS events occur when ONTAP encounters issues associated with the link status changes of IOXM switch ports.
acp.ioxm.port.down
Severity
INFORMATIONAL
This message occurs when the link status of one or more ports from the IOXM switch changes from "up" to "down".
Corrective Action
Verify that all cables in the IOXM switch ports are seated properly.
Syslog Message
IOXM switch port %d is down.
port_num (INT): Switch port number of the IOXM switch.
acp.ioxm.port.up
Severity
INFORMATIONAL
This message occurs when the link status of one or more ports from the IOXM switch changes from "down" to "up".
Corrective Action
(None).
Syslog Message
IOXM switch port %d is up.
