acp.ioxm events
Creating your file...
Your file is ready
acp.ioxm.port.down
- Severity
INFORMATIONAL
- Description
This message occurs when the link status of one or more ports from the IOXM switch changes from "up" to "down".
- Corrective Action
Verify that all cables in the IOXM switch ports are seated properly.
- Syslog Message
IOXM switch port %d is down.
- Parameters
port_num (INT): Switch port number of the IOXM switch.
acp.ioxm.port.up
- Severity
INFORMATIONAL
- Description
This message occurs when the link status of one or more ports from the IOXM switch changes from "down" to "up".
- Corrective Action
(None).
- Syslog Message
IOXM switch port %d is up.
- Parameters
