acp.updateconfiguration events
acp.updateConfiguration
- Severity
ALERT
- Description
This message occurs when the Alternate Control Path (ACP) Administrator determines that the SAS shelf I/O module (IOM) supports only the in-band ACP configuration.
- Corrective Action
> Use the "storage shelf acp configure -channel in-band -is-enabled true" command to enable in-band ACP.
- Syslog Message
IOM %s in shelf S/N: %s does not support out-of-band ACP.
- Parameters
inband_id (STRING): Inband ID of the module.
shelf_sno (STRING): Storage shelf serial number of the shelf where the IOM is seated.
