The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
acp.updateconfiguration events
Creating your file...
Your file is ready
acp.updateConfiguration
- Severity
ALERT
- Description
This message occurs when the Alternate Control Path (ACP) Administrator determines that the SAS shelf I/O module (IOM) supports only the in-band ACP configuration.
- Corrective Action
> Use the "storage shelf acp configure -channel in-band -is-enabled true" command to enable in-band ACP.
- Syslog Message
IOM %s in shelf S/N: %s does not support out-of-band ACP.
- Parameters
inband_id (STRING): Inband ID of the module.
shelf_sno (STRING): Storage shelf serial number of the shelf where the IOM is seated.
