The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
acp.voltage events
Creating your file...
Your file is ready
acp.voltage.status.failed
- Severity
INFORMATIONAL
- Description
This message occurs when a 'voltage status' request that was sent to the Alternate Controller Path Processor fails.
- Corrective Action
(None).
- Syslog Message
A voltage status request sent to %s (%s) failed with status (%s), (disk shelf serial number: %s).
- Parameters
inband_id (STRING): In-band ID of the module.
ip (STRING): IP address of the module.
status (STRING): Reason for the 'voltage status' failure.
shelf_sno (STRING): Disk shelf serial number of the shelf where this I/O module is seated.
