acp.voltage events
Creating your file...
Your file is ready
acp.voltage.status.failed
- Severity
INFORMATIONAL
- Description
This message occurs when a 'voltage status' request that was sent to the Alternate Controller Path Processor fails.
- Corrective Action
(None).
- Syslog Message
A voltage status request sent to %s (%s) failed with status (%s), (disk shelf serial number: %s).
- Parameters
inband_id (STRING): In-band ID of the module.
ip (STRING): IP address of the module.
status (STRING): Reason for the 'voltage status' failure.
shelf_sno (STRING): Disk shelf serial number of the shelf where this I/O module is seated.
