api.input events
api.input.invalidSchema
Severity
ERROR
This message occurs when an ONTAPI(tm) API receives extra input parameters as part of the API request or when a required input parameter is missing in the API request. Most often this is due to a bug in the application that initiates the API request.
Corrective Action
The error is due to strict schema validation. You can turn off the input schema validation by using the following CLI commands: $priv set advanced $registry set state.api.schema_input_validate.enable off
Syslog Message
Error in API input schema validation. API name: %s. Detailed error: %s.
apiName (STRING): Name of the ONTAPI API in which something invalid was detected.
detailInfo (STRING): Description of the error in the API input, such as an extra input value or a missing input value.
