api.input events
Creating your file...
Your file is ready
api.input.invalidSchema
- Severity
ERROR
- Description
This message occurs when an ONTAPI(tm) API receives extra input parameters as part of the API request or when a required input parameter is missing in the API request. Most often this is due to a bug in the application that initiates the API request.
- Corrective Action
The error is due to strict schema validation. You can turn off the input schema validation by using the following CLI commands: $priv set advanced $registry set state.api.schema_input_validate.enable off
- Syslog Message
Error in API input schema validation. API name: %s. Detailed error: %s.
- Parameters
apiName (STRING): Name of the ONTAPI API in which something invalid was detected.
detailInfo (STRING): Description of the error in the API input, such as an extra input value or a missing input value.
