cf.multidisk events
cf.multidisk EMS events occur when the node is waiting for the partner to take over, after the node encounters a multidisk error or some other fatal error.
cf.multidisk.fatalProblem
- Severity
ERROR
- Description
This message occurs when the node is waiting for the partner to take over, after the node encounters a multidisk error or some other fatal error.
- Corrective Action
(None).
- Syslog Message
Node encountered a multidisk error or other fatal error while waiting to be taken over. %s.
- Parameters
mdp_msg (STRING): Multi Disk Panic (MDP) string.
