ONTAP EMS reference
cf.multidisk events
cf.multidisk EMS events occur when the node is waiting for the partner to take over, after the node encounters a multidisk error or some other fatal error.
cf.multidisk.fatalProblem
Severity
ERROR
This message occurs when the node is waiting for the partner to take over, after the node encounters a multidisk error or some other fatal error.
Corrective Action
(None).
Syslog Message
Node encountered a multidisk error or other fatal error while waiting to be taken over. %s.
mdp_msg (STRING): Multi Disk Panic (MDP) string.
