ONTAP EMS reference
config.badlocalswitch events
config.badlocalswitch EMS events occur when a disk is found to be attached to a switch, but there are also disks attached via local connections.
config.BadLocalSwitch
Severity
ALERT
This message occurs when a disk is found to be attached to a switch, but there are also disks attached via local connections. Mixed switch-attached and direct-attached disks are an illegal configuration.
Corrective Action
Correct the cabling so that all disks are attached either directly or through switches. Consult the hardware cabling guides at the NetApp technical support site.
Syslog Message
Disk %s is attached to a switch. However, there are also local attached disks. This is an illegal configuration.
disk (STRING): Name of the disk.
