config.badlocalswitch events
config.badlocalswitch EMS events occur when a disk is found to be attached to a switch, but there are also disks attached via local connections.
config.BadLocalSwitch
- Severity
ALERT
- Description
This message occurs when a disk is found to be attached to a switch, but there are also disks attached via local connections. Mixed switch-attached and direct-attached disks are an illegal configuration.
- Corrective Action
Correct the cabling so that all disks are attached either directly or through switches. Consult the hardware cabling guides at the NetApp technical support site.
- Syslog Message
Disk %s is attached to a switch. However, there are also local attached disks. This is an illegal configuration.
- Parameters
disk (STRING): Name of the disk.
