The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.badswitchlocal events
Creating your file...
Your file is ready
config.BadSwitchLocal
- Severity
ALERT
- Description
This message occurs when a disk is found to be attached locally, but there are also disks attached via switches. Mixed switch-attached and direct-attached disks are an illegal configuration.
- Corrective Action
Correct the cabling so that all disks are attached either directly or through switches. Consult the hardware cabling guides at the NetApp technical support site.
- Syslog Message
Disk %s is attached locally. However, there are also switch attached disks. This is an illegal configuration.
- Parameters
disk (STRING): Name of the disk.
