ONTAP EMS reference
config.badswitchlocal events
config.BadSwitchLocal
Severity
ALERT
This message occurs when a disk is found to be attached locally, but there are also disks attached via switches. Mixed switch-attached and direct-attached disks are an illegal configuration.
Corrective Action
Correct the cabling so that all disks are attached either directly or through switches. Consult the hardware cabling guides at the NetApp technical support site.
Syslog Message
Disk %s is attached locally. However, there are also switch attached disks. This is an illegal configuration.
disk (STRING): Name of the disk.
