      config.habadremote events
config.HABadRemote
- Severity
ALERT
 - Description
This message occurs when a remote host adapter is connected to the wrong switch bank.
 - Corrective Action
Examine the cabling to determine which switch bank the local controller host adapters are attached to (the lower-numbered ports or the higher-numbered ports.) Recable the HA of the remote controller to be in the other bank of switch ports.
 - Syslog Message
A remote host adapter is connected to the same switch bank as the local host adapters. This is an illegal configuration.
 - Parameters
(None).
