config.habadremote events
Creating your file...
Your file is ready
config.HABadRemote
- Severity
ALERT
- Description
This message occurs when a remote host adapter is connected to the wrong switch bank.
- Corrective Action
Examine the cabling to determine which switch bank the local controller host adapters are attached to (the lower-numbered ports or the higher-numbered ports.) Recable the HA of the remote controller to be in the other bank of switch ports.
- Syslog Message
A remote host adapter is connected to the same switch bank as the local host adapters. This is an illegal configuration.
- Parameters
(None).
