ONTAP EMS reference
config.oneswitch events
config.oneswitch EMS events occur when the disk is only connected to one switch.
config.OneSwitch
Severity
ALERT
This message occurs when the disk is only connected to one switch.
Corrective Action
(None).
Syslog Message
Disk %s and other disks on this loop are only connected to one switch. For availability reasons, it should be connected to two separate switches.
disk (STRING): name of the disk
