The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.oneswitch events
Creating your file...
Your file is ready
config.OneSwitch
- Severity
ALERT
- Description
This message occurs when the disk is only connected to one switch.
- Corrective Action
(None).
- Syslog Message
Disk %s and other disks on this loop are only connected to one switch. For availability reasons, it should be connected to two separate switches.
- Parameters
disk (STRING): name of the disk
