wafl.s2c events
wafl.s2c.snap.check.failed
Severity
ERROR
This message occurs when SnapMirror® logical transfer is not possible due to incompatible Snapshot copy.
Corrective Action
Create new Snapshot copy on the source volume and use that for Logical transfer.
Syslog Message
SnapMirror operation failed in volume '%s%s%s' for Snapshot ID %d because %s.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
snapId (INT): Identifier for the Snapshot(tm) copy.
reason (STRING): Specific reason for failure.
wafl.s2c.snap.lang.mismatch
Severity
ERROR
This message occurs when SnapMirror® restore cannot proceed due to language mismatch at source and destination end.
Corrective Action
Create new volume with correct language settings.
Syslog Message
SnapMirror operation failed in %s because of language mismatch between source and destination.Language at destination: '%s'. Language at source: '%s'.
src_lang_setting (STRING): Language setting at source.
dest_lang_setting (STRING): Language setting at destination.
