ONTAP EMS reference
wafl.s2c events
wafl.s2c EMS events occur when ONTAP encounters issues associated with SnapMirror® logical transfer operations.
wafl.s2c.clone.vvbn.vmap.bad
Severity
NOTICE
This message occurs when SnapMirror® detects a missing clone block in the volume block map metafile. The system will attempt to recreate the snapshot on the endpoint to recover from this condition.
Corrective Action
(None).
Syslog Message
SnapMirror operation failed on volume "%s" because of a missing clone block %llu in the volume block map metafile. Relationship will attempt a rebaseline to fix.
vol (STRING): Name of the volume.
vvbn (LONGINT): Virtual volume block number.
wafl.s2c.snap.check.failed
Severity
ERROR
This message occurs when SnapMirror® logical transfer is not possible due to incompatible snapshot.
Corrective Action
Create new snapshot on the source volume and use that for Logical transfer.
Syslog Message
SnapMirror operation failed in volume '%s%s%s' for snapshot ID %d because %s.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
snapId (INT): Identifier for the snapshot.
reason (STRING): Specific reason for failure.
wafl.s2c.snap.lang.mismatch
Severity
ERROR
This message occurs when SnapMirror® restore cannot proceed due to language mismatch at source and destination end.
Corrective Action
Create new volume with correct language settings.
Syslog Message
SnapMirror operation failed in %s because of language mismatch between source and destination.Language at destination: '%s'. Language at source: '%s'.
src_lang_setting (STRING): Language setting at source.
dest_lang_setting (STRING): Language setting at destination.
