wafl.s2c events
wafl.s2c EMS events occur when ONTAP encounters issues associated with SnapMirror® logical transfer operations.
wafl.s2c.snap.check.failed
- Severity
ERROR
- Description
This message occurs when SnapMirror® logical transfer is not possible due to incompatible Snapshot copy.
- Corrective Action
Create new Snapshot copy on the source volume and use that for Logical transfer.
- Syslog Message
SnapMirror operation failed in volume '%s%s%s' for Snapshot ID %d because %s.
- Parameters
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
snapId (INT): Identifier for the Snapshot(tm) copy.
reason (STRING): Specific reason for failure.
wafl.s2c.snap.lang.mismatch
- Severity
ERROR
- Description
This message occurs when SnapMirror® restore cannot proceed due to language mismatch at source and destination end.
- Corrective Action
Create new volume with correct language settings.
- Syslog Message
SnapMirror operation failed in %s because of language mismatch between source and destination.Language at destination: '%s'. Language at source: '%s'.
- Parameters
src_lang_setting (STRING): Language setting at source.
dest_lang_setting (STRING): Language setting at destination.
