ONTAP EMS reference
dbs.bulk events
dbs.bulk EMS events occur when a distributed block store event related to bulk volume operations occurs.
dbs.bulk.op
Severity
NOTICE
This message occurs when a distributed block store event related to bulk volume operations such as backups, restores, making of Snapshot copies, or cloning occurs. If the original distributed block store event specifies multiple drives, then an EMS event is generated for each drive.
Corrective Action
None.
Syslog Message
A distributed block store event \"%s\" of type \"%s\" for Service ID %u on node %u Drive ID = %u. Event ID = %u.
evtMessage (STRING): Description of the distributed block store event, including context details.
evtType (STRING): Type of the original distributed block store event.
serviceID (INT): Service ID that identifies the associated distributed block store service. It is "0" if there is no associated service.
nodeID (INT): Node ID number of the associated node. It is "0" if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is "0" if there is no associated drive.
evtID (INT): Distributed block store event ID number.
evtDetails (STRING): Specific details of the distributed block store event. It might a string, in JSON format, or empty.
