The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
crypto.import events
Creating your file...
Your file is ready
crypto.import.failed
- Severity
ALERT
- Description
This message occurs when the import of a cryptographic key fails.
- Corrective Action
This message might be seen when attempting to bring an encrypted volume online. Contact NetApp technical support if manual attempts to bring the encrypted volume online fail.
- Syslog Message
ERROR: Import of key with key ID %s failed. Additional information: %s.
- Parameters
key_id (STRING): Key ID for the cryptographic key.
msg (STRING): Associated failure message.
