api.engine events
api.engine EMS events occur when the ONTAPI® engine is unexpectedly terminated.
api.engine.killed
- Severity
EMERGENCY
- Description
This event is posted when the ONTAPI® engine is unexpectedly terminated. The ONTAPI APIs cannot be executed until the system is rebooted.
- Corrective Action
Reboot the controller. If the problem persists, contact Contact NetApp technical support.
- Syslog Message
Error in API Engine. Engine name: %s.
- Parameters
engineName (STRING): Name of the execution engine (e.g., "m" or "d").
