      api.engine events
api.engine.killed
- Severity
EMERGENCY
 - Description
This event is posted when the ONTAPI® engine is unexpectedly terminated. The ONTAPI APIs cannot be executed until the system is rebooted.
 - Corrective Action
Reboot the controller. If the problem persists, contact Contact NetApp technical support.
 - Syslog Message
Error in API Engine. Engine name: %s.
 - Parameters
engineName (STRING): Name of the execution engine (e.g., "m" or "d").
