ONTAP EMS reference
api.engine events
api.engine.killed
Severity
EMERGENCY
This event is posted when the ONTAPI® engine is unexpectedly terminated. The ONTAPI APIs cannot be executed until the system is rebooted.
Corrective Action
Reboot the controller. If the problem persists, contact Contact NetApp technical support.
Syslog Message
Error in API Engine. Engine name: %s.
engineName (STRING): Name of the execution engine (e.g., "m" or "d").
