ONTAP EMS reference
ffm.dataip events
ffm.dataip EMS events occur when ONTAP encounters issues associated with hosting of a data IP address on a node.
ffm.dataip.failedToHost
Severity
NOTICE
This message occurs when a data IP address was failed to host on the node. Data access through this IP address is not available.
Corrective Action
(None).
Syslog Message
Data IP address %s was failed to host by the NFS protocol service on the node %s (ID: %u).
dataip (STRING): The IP address that was failed to host.
nodename (STRING): Name of the node on which the data IP was failed to host.
nodeid (INT): Unique identifier of the node on which the data IP was failed to host.
ffm.dataip.successfullyHosted
Severity
NOTICE
This message occurs when a data IP address was successfully hosted on the node. Data access through this IP address is now available.
Corrective Action
(None).
Syslog Message
Data IP address %s was hosted by the NFS protocol service on the node %s (ID: %u).
dataip (STRING): The IP address that was hosted.
nodename (STRING): Name of the node on which the data IP was hosted.
nodeid (INT): Unique identifier of the node on which the data IP was hosted.
