ONTAP EMS reference
monitor.partnercontroller events
monitor.partnercontroller EMS events occur when both controllers are configured as an HA (high-availability) pair, but the partner controller is not present.
monitor.partnerController.notPresent
Severity
ALERT
This message occurs when both controllers are configured as an HA (high-availability) pair, but the partner controller is not present. The system fan will run at a higher speed to prevent overheating due to the non-optimum air flow with only one controller in place.
Corrective Action
Put the partner controller back into the HA configuration; otherwise, the system fan will run at a higher speed to prevent overheating due to the non-optimum air flow with only one controller in place.
Syslog Message
Both controllers are configured as an HA (high-availability) pair, but the partner controller is not present. The system fan will run at a higher speed to prevent possible overheating.
(None).
