monitor.partnercontroller events
Creating your file...
Your file is ready
monitor.partnerController.notPresent
- Severity
ALERT
- Description
This message occurs when both controllers are configured as an HA (high-availability) pair, but the partner controller is not present. The system fan will run at a higher speed to prevent overheating due to the non-optimum air flow with only one controller in place.
- Corrective Action
Put the partner controller back into the HA configuration; otherwise, the system fan will run at a higher speed to prevent overheating due to the non-optimum air flow with only one controller in place.
- Syslog Message
Both controllers are configured as an HA (high-availability) pair, but the partner controller is not present. The system fan will run at a higher speed to prevent possible overheating.
- Parameters
(None).
