nv.extension events
nv.extension EMS events occur when ONTAP encounters issues associated with NVRAM segment operations.
nv.extension.disabled
- Severity
INFORMATIONAL
- Description
This message occurs when NVRAM segments of a nvlog client are disabled in a NVRAM section.
- Corrective Action
(None).
- Syslog Message
%s segments have been disabled in %s NVRAM section.
- Parameters
cid (STRING): Nvlog client ID.
nv_section (STRING): The NVRAM section in which the nvlog client segments are disabled.
nv.extension.enabled
- Severity
INFORMATIONAL
- Description
This message occurs when NVRAM segments of a nvlog client are enabled in a NVRAM section.
- Corrective Action
(None).
- Syslog Message
%s segments have been enabled in %s NVRAM section.
- Parameters
nv_section (STRING): The NVRAM section in which nvlog client segments are enabled.
nv.extension.failed
- Severity
ERROR
- Description
This message occurs when nvlog client segments cannot be enabled in a partner NVRAM section following a controller failover. When this event occurs, the system continues to operate, but with diminished performance due to the increased failover load coupled with decreased NVRAM capacity for logging.
- Corrective Action
For a System ID-related failure message, verify that each member node in this configuration is assigned a valid and unique system ID by using the "system show -fields systemid" command. Do not physically move a controller or NVRAM card in an HA or MetroCluster(tm) configuration. A failure message of "Configuration Recovery Needed" means that a reboot is needed to recover persistent MetroCluster configuration at a switchover site.
- Syslog Message
Client segments cannot be enabled in the %s NVRAM section, because of %s.
- Parameters
nv_section (STRING): NVRAM section in which nvlog client segments cannot be enabled.
failure_reason (STRING): Reason client segments cannot be enabled in this partner NVRAM section.
