nv.extension events
nv.extension.disabled
Severity
INFORMATIONAL
This message occurs when NVRAM segments of a nvlog client are disabled in a NVRAM section.
Corrective Action
(None).
Syslog Message
%s segments have been disabled in %s NVRAM section.
cid (STRING): Nvlog client ID.
nv_section (STRING): The NVRAM section in which the nvlog client segments are disabled.
nv.extension.enabled
Severity
INFORMATIONAL
This message occurs when NVRAM segments of a nvlog client are enabled in a NVRAM section.
Corrective Action
(None).
Syslog Message
%s segments have been enabled in %s NVRAM section.
nv_section (STRING): The NVRAM section in which nvlog client segments are enabled.
nv.extension.failed
Severity
ERROR
This message occurs when nvlog client segments cannot be enabled in a partner NVRAM section following a controller failover. When this event occurs, the system continues to operate, but with diminished performance due to the increased failover load coupled with decreased NVRAM capacity for logging.
Corrective Action
For a System ID-related failure message, verify that each member node in this configuration is assigned a valid and unique system ID by using the "system show -fields systemid" command. Do not physically move a controller or NVRAM card in an HA or MetroCluster(tm) configuration. A failure message of "Configuration Recovery Needed" means that a reboot is needed to recover persistent MetroCluster configuration at a switchover site.
Syslog Message
Client segments cannot be enabled in the %s NVRAM section, because of %s.
nv_section (STRING): NVRAM section in which nvlog client segments cannot be enabled.
failure_reason (STRING): Reason client segments cannot be enabled in this partner NVRAM section.
