      disk.encryptsupportreqd events
disk.encryptSupportReqd
- Severity
ALERT
 - Description
This message occurs when ONTAP® software detects one or more nonencrypting drives or non-FIPS-certified self-encrypting drives (SEDs), but the environment variable 'bootarg.storageencryption.support' is set to "true" to indicate that all drives must be FIPS-certified.
 - Corrective Action
Remove all non-FIPS-certified SEDs and standard drives.
 - Syslog Message
Detected nonencrypting drive or non-FIPS-certified drive %s, but only FIPS-certified drives are supported on this node. %d of %d drives checked are FIPS-certified.
 - Parameters
disk (STRING): Name of a drive that is not FIPS-certified.
encrypting_disks (INT): Number of FIPS-certified drives detected.
disk_count (INT): Total number of drives checked. For a high-availability pair, this might be fewer than the total number of drives.
